Radiator loosing fluid, no visable leak
snowranch56's Avatar
03-06-03, 06:36 PM   #1
snowranch56
I have a 96Ford Ranger, 4cyl., 105K miles. It recently started loosing coolant, but I can not find any leaks. Put a new radiator cap on, still loosing fluid. Top radiator hose gets hot, bottom hose stays cool. Radiator cap cool after 1 hr drive home. Temp on gauge stays in normal range. No fluid at weep hole on pump. Heater hoses hot. Thermostat changed 35000 miles ago. Any suggestions? Clogged radiator?
Daniel Wachtel's Avatar
03-06-03, 06:59 PM   #2
If your losing coolant and can't see it run a compression check and see if you need a head gasket
WeldGod's Avatar
03-06-03, 11:52 PM   #3
Yep, check the head gasket
Joe_F's Avatar
03-07-03, 05:53 AM   #4
Joe_F
Yup. A shop can use a gas analyzer to check for HC in the coolant and advise you as noted here.
03-07-03, 07:40 AM   #5
snowranch56
Thanks for the suggestions. I'll check pressure this weekend. But I've check the oil for water, gas mileage is the same as it has been for the past 105K miles, engine runs like a champ. I would think a head gasket problem would show more symptoms.????
Joe_F's Avatar
03-07-03, 07:40 AM   #6
Joe_F
In early stages, no.
SpiderGear's Avatar
03-07-03, 04:07 PM   #7
SpiderGear
Have you noticed any white smoke coming from the tail pipe on start ups or while driving???
Have you tried removing the rad cap when cool and then start the engine. Watch for bubbles forming in the rad cap hole or coolant being pushed out. Also the coolant could be leaking into the exhaust caused by a blown headgasket !! Like the others have mentioned!!
