:cool: Car is a 1996 Camaro V6 3800 engine. Power windows won't work. No sound no nothing. Have changed out all fuses inside car and one in the engine in the relay-fuse box. Won't budge at all.. any ideas?Read More
I have a 1994 Ford Ranger with rear anti-lock brakes. It has a 2.3l engine and a 5 speed manual transmission. My problem is that the ABS light comes on at random times. It does not flicker, but stays on for a few minutes before going out. The "regular" brake light never comes on and the brake fluid level is fine. I have checked for brake leaks and found none. The brake pads are good and the tires are the correct size and are relatively new. What causes the light to come on?Read More
