Ford Expedition Rear Axle Removal
Old 03-08-03, 03:49 PM
axleboy
My mechanic is stumped by an S shaped clip in the differential
of my 2000 Ford Expedion (2 x 4, 4.6 liter). This S shaped clip
will not allow him access to the c shaped clip on the end of
the axle shaft for removal. He is trying to change the axle
seal which has failed. Does anyone know how to remove this S
shaped clip? Thank You
Old 03-09-03, 07:11 AM
Joe_F
You're at the wrong mechanic. You shouldn't have to tell him anything how to fix it!
I'm sure he's got an Alldata machine which will have the rear end and axle R&R procedure or he's got some sort of service manual!!!
Also, this a 2000 vehicle. Any rear end trouble should still be covered by a factory warranty, even if over the mileage a little bit. Shouldn't have rear end problems on a 2000 vehicle unless you've got ALOT of mileage.
