95 4wd BLAZER seized brake caliper on LF
Old 03-09-03, 12:16 PM
itgl72
I have a 95 blazer 4wd with ABS brakes and disks in the front.
Well I noticed my LF caliper was acting funny.
I was no longer able to compress the piston when I was putting in new pads. So I bought a new caliper. Bleed the 4 wheels.
I did notice upon bleeding the last wheel, the actual LF caliper I just installed, that the pedal did not go all the way down like the other wheels dead when I loosened the bleeding screw. (I had someone pump the brake and hold it while I opened the bleeders)
But I started the car, pumped it, loosened the bleeder screw on the LF, a shot came out, and I figured, OK, its bled. Its OK now.
Well I made sure I had brake fluid taped off, took it for a ride and notice it pulling to the drivers side a bit bring it home jack up the LF wheel and sure enough it is locked up and I even smell some burning.
Can it be my newly purchased brake caliper can be faulty?
Did I forget to do something?
Your suggestions are welcome!
Old 03-09-03, 01:43 PM
Joe_F
Replace both brake calipers and both flexible rubber lines. Rebleed the system and then tell us what you've got.
I suspect a clogged brake hose. Very common problem.
Old 03-11-03, 02:20 AM
WeldGod's Avatar
Unless you had closed the bleeder screw while they had the peddle depressed and fluid was coming out, it sucks are back in the line.
Old 03-11-03, 04:41 AM
itgl72
I just dont have the tools I need here since I moved.
I don't even have a good set of vicegrips anymore. I couldnt even get the darn rubber brake hose all the way off, just started to strip and round.
I gave it 2-3 days effort, but now its going to the garage.
