1990 cutlass ciera starter
Old 03-11-03, 01:01 PM
110school
My starter is starting to wind , may be going soon . I know the older Gm's
were 2 or 3 bolts under neath near the firewall. This vehicle is front-wheel
drive . Is it harder to get at ?? . Anything tricky about removing it , and what size rachets or special tools are needed ? Does anything else need to be removed first ??
Old 03-11-03, 08:59 PM
Joe_F
Common handtools found in any Craftsman or other quality set will do it.
Pick up a repair manual from your library to guide you in the R&R instructions. Use a Delco rebuilt for best results.
You don't mention which engine, can't help much.
Old 03-12-03, 12:06 AM
WeldGod's Avatar
On some of GMís front wheel drive cars a swivel socket and a 6in extension are required. But, you could tell real quick by crawling under there and giving it a look.
