1997 blazer 4x4
Old 03-13-03, 11:26 AM
redneck
1997 blazer 4x4
A friend took his blazer into shop complaining of noise--said it sounded like a wheel bearing--I did not get a chance to look at it.
Shop said yes, right front wheel bearing was bad--cost to repair was $600!! Shop said a "sensor" needed replaced and that was the expensive part. Anyone know what "sensor" they could be talking about?--seems high!
Old 03-13-03, 03:50 PM
Joe_F
Most likely an ABS wheel sensor. Depending on the cost of parts and the repairs needed, it sounds a bit steep.
Old 03-13-03, 04:03 PM
On those vehicles the wheel bearing and antilock wheel speed sensor are 1 part with a wiring harness attached also.The part should be around 400 bucks.Labor about 1 and 1/2 hour that depends on the hourly rate at the shop and the time for diagnosis.So the price while a bit scary may not be out of line.
Old 03-14-03, 01:11 AM
WeldGod's Avatar
ABS=All Bucks Spent
Old 03-14-03, 12:07 PM
Here's what Alldata says about the parts and replacement. You can find these part numbers for 40% to 50% off at www.gmpartsdirect.com
Double check with your local GM parts dealer.
Parts
OEM Part . Price
Wheel Speed Sensor
Wheel Speed Sensor, ABS
Front. . . Right . 15727018 . $90.65
Labor
Wheel Speed Sensor
Replace Wheel Speed Sensor
Front. Four Wheel ABS
One Side 1.1
Parts
OEM Part . Price
Wheel Bearing
Front- Hub & Bearing . 7470013 $448.44
Contact dealer
Labor Wheel Bearing
Replace Front Hub & Bearing
One Side . 0.8
Notes.. Does Not Include Alignment.
Old 03-18-03, 12:07 PM
redneck
yep, just saw his invoice, parts were over $400, and with the labor rates around here--$600 is not out of the question. I was not aware of the sensor and bearing housing as one piece--thanks.
