Turn signal relay vs. flasher for 96 Eagle Vision
KariRN's Avatar
03-14-03, 04:17 PM   #1
KariRN
Hi! I have searched the site and tried your suggestions for helping my neighbor fix his turn signals. For a while, they stayed lit when he turned them on, then quit working all together. There is no noise at all coming from the dash when the turn signals are activated. His hazards do work. Without taking apart the underside of the dash (which I would do if it were my car, but since it's not...), I can't seem to locate anything resembling a flasher. It appears from calling a parts store to look in the Wagner book as you suggested, that this vehicle has a relay instead of a flasher. The parts stores didn't have a part, said it would have to be obtained from a dealer. Any other suggestions?
Kari
bejay's Avatar
03-14-03, 07:24 PM   #2
have you checked the fuses, this car does have an electronic flasher relay but i doubt that is the problem cause they do not fail very often, seeing how it isnt your car you might suggest taking it to a shop to trace down the problem.
KariRN's Avatar
03-14-03, 08:04 PM   #3
KariRN
I forgot to mention the fuse, we did check that first, it appeared fine, and we even replaced it with a new one, the turn signals still didn't work.
Kari
Joe_F's Avatar
03-15-03, 11:13 AM   #4
Joe_F
Call up any Chrysler dealer and ask for the replacement part and the location. Their parts microfiche should tell you both.
KariRN's Avatar
03-16-03, 02:47 PM   #5
KariRN
Thank you for all your advise, I will relay this to my neighbor.
Kari
