Re Gluing Rubber Around Inside Of Doors
Old 03-14-03, 06:06 PM
skarch
Question Re Gluing Rubber Around Inside Of Doors
I HAVE A 1995 INTREPID
THE RUBBER DRAFT GASKETS THAT GO AROUND THE INSIDE OF EACH DOOR HAVE COME LOOSE FROM THE STEEL GROOVES THAT IT SLIDE INTO. WHAT TYPE OF ADHESIVE WILL WORK, WHAT IS THE PROPER WAY TO DO THIS. I HAVE BEEN PUSHING IT BACK IN THE GROOVE IN ONE SPOT WHICH CAUSES IT TO COME LOOSE IN ANOTHER SPOT. IS THERE ALSO A MINIMUM TEMPERATURE TO DO THIS IN, I LIVE IN ONTARIO,CANADA.
Old 03-14-03, 06:57 PM
joe crosgrey
ive used a glue called goop get it at canadian tire it works great for car trim and such
Old 03-15-03, 12:15 PM
Joe_F
Kill the caps. No need to shout.
Use 3M black weatherstrip adhesive. If that doesn't work, the strip may be worn or stretched out and needs to be replaced.
