car problems
AngieL's Avatar
03-18-03, 12:14 PM   #1
AngieL
car problems
i have a 1994 cheverolet camaro z28, with the 5.7 liter lt1 engine
the symptoms are what i thought was the pass key system because i am able to start the vehicle but it shuts right off. so i thought the key was warn out and wasnt sending a resistance signal anymore so i had the key tested at a dealership and it tested fine so then i noticed after messing with it for a while that when i turn the key to the full on position or what i think is called auxilary just before the cranking position, is no longer working there is no engine lights coming on and the gauges arent powering up either and now the car wont even crank with the key in cranking position and its not the battery because i have voltage reading. oh and one other funny thing, i tryed to put my snap on scanner on it the see if i could pull any codes and it wont comunicate with the ecm.... any helpful suggestions would be appreciated, i think its the ingnition cylinder but maybe you can tell me thanks
davo's Avatar
03-18-03, 03:33 PM   #2
Check your ignition switch not the lock cylinder.
