99 Ford Explorer
duce110's Avatar
03-21-03, 11:44 AM   #1
duce110
99 Ford Explorer
how can I change the transfer case oil on my ford explorer
Joe_F's Avatar
03-21-03, 12:47 PM   #2
Joe_F
What does your service manual or autolibrary.org have to say?
WeldGod's Avatar
03-22-03, 01:52 AM   #3
There is two plugs the upper one is the fill plug the lower one is the drain plug. Look in your owner’s manual for the correct type of fluid. But I think you have one of the T-Cases that take ATF fluid.
taxxman2k's Avatar
04-18-03, 06:57 AM   #4
taxxman2k
Yes it takes ATF and is very easy. The tranny takes mercron V and I "think" the same goes in the t-case. But you can call a dealer to check. The plugs simply take the end of a ratchet with no socket on it. You will need a pump to get the new fluid in. Only takes a few minutes.
