wiper arm
Old 03-22-03, 11:21 AM
skarch
Question wiper arm
I HAVE A 1995 INTREPID
THE WIPER LINKAGE ARM THAT ATTACHES THE ARM FROM THE MOTOR TO THE ARM THAT MOVES BOTH WIPER BLADES HAS COME APART AT THE COMPRESSION FITTING. THIS AREA IS EXPOSED AT THE DRIVER SIDE BELOW THE WINDSHIELD. I HAVE WRAPPED THE TWO ARMS TOGETHER WITH WIRE AND IT IS WORKING.
CAN I BUY ANOTHER PLASTIC COMPRESSION FITTING AND REPLACE IT OR DO I HAVE TO REPLACE THE LINKAGE AS WELL.
IT APPEARS THAT IF I BRAKE OFF THE PLASTIC FITTINGS AND ATTACH BOTH ARMS TOGETHER WITH A BOLT AND WASHERS IT MAY DO IT, I BELEIVE THE ARM ONLY MOVES SIDE TO SIDE
Old 03-22-03, 11:30 AM
darrell McCoy
Hit your local dealer for the part. I am sure the service mngr will show you how to repair it. Fix it right, do not jury rig wipers.
Old 03-22-03, 01:09 PM
Replace the linkage. you can find discounted Chrysler parts on the web such as at www.kollerdodge.com Double check these part numbers as I'm not always perfect
4723416 1 LINKAGE, Upper Wiper ***
4723417 1 LINKAGE, w/Crank Arm, Lower ***
Discount prices valid for online orders only.
Part # Description List Sale
4723416 LINKUPPE $ 61.70 $ 42.55
4723417 LINKWIPE $ 44.50 $ 30.70
Old 03-23-03, 05:19 PM
Joe_F
I agree. Don't gamble with safety items.
