1999 chev astro missing
Old 03-22-03, 07:09 PM
Hi
I've got a 1999 astro, that in damp or wet weather, misses or stutters when you accelerate. It starts up fine and runs smooth as long as I don't step on the gas. I tried adding some gas line fluid to the tanks of gas..and I even tried different gas companys..and even put in the high test(which was painful considering the cost). I took it the the garage and the wiring and plugs and distributor was changed...and it's still doing it. Any other ideas will be appreciated.
Thanks
Old 03-22-03, 07:19 PM
was the distributer cap changed? or just the distributer. if the distributer cap wasnt changed i would start there, you may have to leave it at a shop next time its wet outside so they can actually see the problem and determine what is causing it.
Old 03-23-03, 02:00 AM
WeldGod's Avatar
I agree with bejay moisture in your cap could cause you symptoms. Or running the engine with to much air in the air/fuel mixture could be causing your misfires.
Old 03-23-03, 06:44 AM
Thanks..I'll have those checked out..but you'd think the mechanic would have done that already?Hmmm?
Old 03-23-03, 07:20 AM
Joe_F
Never assume--it could have easily been missed and it sounds like your problem. I agree.
Old 03-24-03, 02:39 PM
Ok..had the injectors flushed and it is running fine now...except now the oil presure gauge moves back and forth depending on the amount I step on the gas...why is it doing this all of a sudden?
Old 03-24-03, 09:49 PM
WeldGod's Avatar
It should move back an forth depending on how fast the engine is turning. Soundís like the might have accidentally fixed it.
