Shifting problem
Old 03-26-03, 06:25 AM
AZbowhunter's Avatar
Angry Shifting problem
I have a 1988 Nesson Maxmia with auto. shift. The prob. is that the only way that I can shift into drive is to manually shift into second range first then into drive. Same way when going from reverse to drive. After I get into drive the trans. shifts fine like it should. ?????
Don
Old 03-26-03, 10:13 AM
Joe_F
I believe this question was answered and asked already.
Check the linkage for proper operation. Also, if the tranny fluid has not been changed in a while, now is the time to do it.
Barring that, it sounds like internal failure of the unit---rebuild time
