1994 Ford F-150
Old 03-29-03, 11:31 AM
ahiggins
Question 1994 Ford F-150
Dear Master Mechanic:
I have a 1994 Ford F-150 Pickup truck with a 5.0 engine that is blowing white smoke from the tail pipe. The smoke smells like gas & oil. The oil stick smells like gas. A computer check stated that it has low compression in one of the cylinders. Help? I had just changed the oil the day before and put injection cleaner in the gas tank, then I started having this problem. Prior to that it ran just fine. It has 111,000 miles. Any suggestions as to what this could be?
Any tips would be appreciated.
Thanks,
[email protected]
Old 03-29-03, 07:01 PM
the_tow_guy's Avatar
White smoke is generally coolant/water vapor.
"Gas" smoke, as in running excessively rich, would be black.
Oil smoke is bluish.
Blown head gasket would be a possibility here, but you'll need some more investigation. An inspection of the spark plugs would be a good starting point.
Other things to check: Are you losing coolant (have to put water in the coolant tank frequently)?; is the oil on the dipstick discolored or have visible water in it? Has your gas mileage gone down?
Probably going to want some professional assistance on this one. A good garage will have the proper test equipment to narrow down the problem.
Old 03-30-03, 03:17 AM
WeldGod's Avatar
UH OH, sounds to me like a busted head or cracked block.
Old 03-30-03, 05:47 AM
Joe_F
Pay attention to the smell of the smoke. Does it smell sweet like syrup? If it does, blown head gasket or cracked block/cylinder head.
In that case, order a rebuilt engine from Ford and replace the engine. A shop can confirm that you do indeed have a blown gasket.
Trackbacks are On
Pingbacks are On
Refbacks are On
