car wont statrt
I have a 1995 probe 4cyd that was put in the ditch by daughter. the car seems to be ok but will not start.It will turn over but will not firerup. I have been told that there is reset button for the fuel pump if so. Where is it located. I dont think the car is geting fuel.
Hi,
The switch that you are refering to should be in the rear hatch area. Probably behind one of the covers back there. A lot of the times the only thing that you will see is a hole with a white buttom. Push it and you should have it made.
Jackie
Jackie
