Transmisson- 92 Buick at times will not go into gear when stopped
Old 03-30-03, 11:39 AM
kramj44
I have a 92 Buick Regal with 70,000 miles. Recently I have been having trouble with my transmission. At times, when I start my car and put it in drive or reverse it will not go into gear. If I wait a few seconds put it in neutral and try again it will go into gear. Also, when I come to a full stop it will sometimes do the same thing. Do I need a new transmission or could it be something else? I have checked my transmission fluid level and it is fine.
Thanks for any help that could be provided.
Old 03-30-03, 12:38 PM
Joe_F
Probably a weak pump---sign of impending internal failure. Have a good tranny shop look at both the linkage and the tranny by going for a test drive with you.
Old 03-30-03, 12:45 PM
darrell McCoy
Might also check alldata TSB's. Seems Buick had a few problems in that era. (Late Trans engagement) Else ask the dealer for a TSB. Bear in mind however that a TSB may not Pertain to your auto, that is usually checked by the VIN.
