brakes "90" GMC 1 ton van, repaired,still locking
chumiser's Avatar
New Member
FL
04-02-03, 03:20 PM   #1
Hi Guys
Replaced front passenger brake caliper that was locking. Front fine now back brakes begin to lock. Replaced both back cylinders + lines and bled . All in terrible condition. Right rear still locking. Auto adjust on both wheels seems fine and turns easy. hardware on back wheels looks good and functional as do shoes. During all these steps after replacing front caliper, both back wheels would lock individually at one point or another.
Whats next??
Thank you
Rob
WeldGod's Avatar
04-02-03, 07:34 PM   #2
I would check if you van is equipped with proportioning valves. If it is equipped with one its time for an adjustment. Also make sure you lines are clean and getting even flow to every wheel.
chumiser's Avatar
New Member
FL
04-03-03, 04:41 AM   #3
Thanks weldgod
I am not familiar with this valve. I see that it has one. The lines off master lead to it. Can i adjust this simply or do I need detailed from manual?. This is my friends van hence no manual.
All the best
Rob
Joe_F's Avatar
04-03-03, 05:41 AM   #4
Joe_F
I'd pitch the valve. They are fairly cheap through GM and this is a common failure on these vans.
Also, I would change both rubber caliper flex lines for safety as well. Common problem too.
chumiser's Avatar
New Member
FL
04-04-03, 05:37 AM   #5
my friend,
one more q?
Any electronics before valve that could be at fault or are connections to fail safe censors??
Thanks a bunch
Joe_F's Avatar
04-04-03, 05:37 AM   #6
Joe_F
If the van has rear wheel ABS, sure.
chumiser's Avatar
New Member
FL
04-07-03, 12:17 PM   #7
brakes STUMBLE "90" GMC 1 ton van, repaired,still locking
Hi again
We just spent 2 1/2 hours at dealer. We have the proportion valve but the anti-lock portion of the valve is discontinued and no longer available in this van as determined by the dealer. He had no answers for us(very helpful though). Any thoughts on this application as is with the old anti-l unit? apparently this was one of the first out for that period and is attached to the valve by the same bracket a bolt and brake lines. It has a four prong connector. The dealers did not even know what it was. The factory did not, but a Mech. on duty recognized it. Can this be discontinued if it is a part of our braking problem? Is it likely to cause the condition we are having and if so can we fix that part or use some other from a different year or make? We are not to concerned with the ABS on this van.
Thanks
Rob
Joe_F's Avatar
04-07-03, 01:12 PM   #8
Joe_F
A couple of things:
1) See if the aftermarket has rebuilt ones. Try A-1 Cardone (sold through most parts stores)
2) Have the dealer's parts dept fetch the part # and put it on their locator service to see if any turn up anywhere at another dealer. In turn, your dealer can order it from that dealer.
3) A used unit is a possibility, but is a gamble.
If the dealer has been helpful thus far, see if they will go the extra mile for you. They seem like they are on the right track.
The hardware may "look" good but is likely wasted. Change it and don't gamble.
WeldGod's Avatar
04-08-03, 01:50 AM   #9
I Agree
