04-02-03, 04:34 PM
Bahamaboy
1990, Acura Integera, auto,4cyl
When the car is cold (like first thing in the morning or during cold weather) the car gets into second gear and does not advance in gears untill the engine or transmission (your pick) is warmed up.
I bought the car almost a year ago and it has nearly 200k miles on it.
I dont know when the trans filter and oil were changed but I will do them soon. I just thought it may be some other problem.
A little insight would be nice - Thanx
04-02-03, 07:20 PM
I would start with the fluid change and filter change, thick fluid with some water in it could cause slow shifting until the fluid is warmer. Check your vacuum line to the modulator and the modulator. That is best case scenario other wise you are probably having problems with you pumps or valve bodies.
04-02-03, 07:25 PM
Bahamaboy
Originally posted by WeldGodthanx, ill work on changing the filter and oil asap, preciate the advice
04-04-03, 02:54 PM
Bahamaboy
reply
I called around trying to find a transmission filter but was told that they dont carry it or the car is similar to a honda accord and doesnt use a filter. Could this be possible?
04-04-03, 03:05 PM
It is a drain and refill transmission and I think it gets checked without the engine running,which is unusual for automatics so check your owners manual to be sure.The manual should also state the proper fill amount ,use the factory type fluid,important for honda trannys,could be the problem if someone added a different type at some point.
