96 Pontiac Sunfire not starting
Old 04-04-03, 11:18 AM
daboys
I have a 96 Pontiac Sunfire. It just will not start. I have lights, horn, radio, everything, but when I turn the key, it just makes a clicking sound. My husband is convinced it is the battery. He has checked the starter and replaces a relay by the battery. It is still just clicking. What could cause this? If it is the battery, wouldn't it start when we tried to jump it? Thank you for any help you can give me.
Old 04-04-03, 02:03 PM
darrell McCoy
No, not necessarily. You may have a bad connection at the starter. Sometime batteries leak and run down the + cable onto the starter. Thus corrosion. I would check the battery first and then start looking for bad connections. If it is not there, the starter/solenoid may be bad. Read Joe's basics, it is pretty informative.
Old 04-04-03, 02:57 PM
Darrell is correct I would check the battery also.GM original equipment batteries have a nasty habit of leaking from the positive post.I would suggest also replacing the affected battery cable.If you don.t and it has acid in it your car will be a no start again soon.
Old 04-04-03, 03:18 PM
Joe_F
See my "Basics" below.
