2001 VW Beetle Rear Brake Repair
meanquuen's Avatar
04-06-03, 10:55 AM   #1
meanquuen
We are in the process of changing the brake pads and cannot get the piston to go in...is there a trick?
Joe_F's Avatar
04-06-03, 12:18 PM   #2
Joe_F
The piston generally screws in. Most parts stores have the special tool that is required. Autozone will rent it to you free of charge in most cases.
bejay's Avatar
04-06-03, 12:18 PM   #3
suggest getting a manual for your vehicle or maybe even a subscription to alldata, alot of vehicle use a tool to compress the caliper while turning the caliper piston, could also have a screw on the back side of the caliper that compresses the caliper, but a repair manual should give you the correct way to compress the calipers.
jthompson's Avatar
04-07-03, 06:47 PM   #4
I wouldn't expect that it would be too different than my wifes 2k jetta(although it could be)
It is indeed one of the twist tools, rented from autozone
meanquuen's Avatar
04-10-03, 08:40 AM   #5
meanquuen
2001 VW Beetle Brakes
Thanks to all that posted a reply to our brake problem.
We also found that you can use neetle nose pliers....
or
a piece of clotheshanger to fit in the groves and a C- Clamp.
Didn't have to use that special tool even though it probably would have made it easier!
Again, thanks for all the replies!
Teresa
Joe_F's Avatar
04-10-03, 08:49 AM   #6
Joe_F
Lol. I guess . Renting the tool is usually a bit easier.
