socket
Old 04-06-03, 04:14 PM
socket
hello
is a deep socket 1/2 inch drive made for a six point 31/32 nut? i can't locate one.
thanx
pete
Old 04-06-03, 04:54 PM
fewalt's Avatar
Pete,
I have my doubts that you have a 31/32 nut.
You sure it's not 15/16 or 1 inch?
fred
Old 04-06-03, 05:19 PM
Joe_F
I agree with Fred.
Old 04-06-03, 05:46 PM
darrell McCoy
only 31/32 I ever saw was used by a plumber. Sort of a stamped type odd ball socket. Dont even remember how many points. Not for mechanical/auto use.
Old 04-06-03, 06:21 PM
WeldGod's Avatar
The only 31/32 socket I have seen is Schaul socket for pluming.
Old 04-07-03, 09:50 AM
schaul socket
you are all right about the 31/32 BUT weldgod said he had a 31/32 schaul socket for plumbing-this is my problem. the set of cowbells or tub wrenches i got had a 31/32 socket to remove a faucet stem in the wall of a shower-it is right handed and the company(kohler) does not know the size wrench to put on it b/c there is no model #. the 31/32 was a tiny bit loose and slipped after a good tug. i shimmed it with a long thin screw driver, and also tapped it on the vise to get it a but snug. it still slipped. the stem is tight but with the right socket it must come out. does the schaul socket have more strenght than the cowbell or tub wrench set ? the plumbing supply store said his too come from taiwan and would be no stronger. i think i tried 15/16 but now i'm not sure. what about that schaul?
pete
Old 04-07-03, 10:15 AM
Joe_F
Pete:
Suggest you ask this on the plumbing forum.
Old 04-07-03, 10:25 AM
i did but thanx anyway-that schaul socket caught my eye
pete
Old 04-07-03, 11:26 AM
WeldGod's Avatar
This is the redneck coming out in me but…… I would just sodder the tool on to the nut. Or cut if off with a grinder.
Old 04-07-03, 12:01 PM
Joe_F
A plumbing supply should be able to help out....go to a plumbing supply, not a big box store. They should have the right tool.
