Car wont start
Old 04-07-03, 04:23 AM
Car wont start
I have a 91 Honda Civic 4 door sedan 1.5 liter engine, 5 speed manual transmission. When I turn the key in the ignition, it makes a fast whirring sound. My first thought was the starter but I wanted to get other opinions.
car was tuned up 10,000 miles ago
timing belt was replaced 40,000 miles ago
I could not get the distributor cap off because the bolts are beginning to strip and I was afraid to make them worse.
Thank-you
Sal
Old 04-07-03, 05:13 AM
raymo8
Sounds like it could be a timing belt. I know that it was replaced only 40,000 miles ago, but maybe it's time for another one. If you can get the distributor cap off, then you will be able to tell if the rotor doesn't spin when you turn the key. Try using vice grips to take the bolts off and then replace them when you put it back.
Old 04-07-03, 05:23 AM
Joe_F
I agree. Sounds like your timing belt is wasted. If you didn't change the water pump when you did the timing belt, good chance the pump leaked coolant onto the belt and wasted it .
Old 04-07-03, 05:54 AM
Hi Joe_F and Raymo8
Thanks for your quick replies.
I got the distributor cap off and the rotor is turning when I try to start the car. I was glad to see that. Any other ideas?
Sal
Old 04-07-03, 09:11 AM
Joe_F
Still start with my "The Basics" below.
Trackbacks are On
Pingbacks are On
Refbacks are On
