1998 Oldsmobile Intrigue
wingplow's Avatar
04-07-03, 03:28 PM   #1
wingplow
I'am back again with a new problem. The right turn signal does not work. I took the bulbs from the right side and put them on the left side and they worked ok.Put the bulbs from the left side in the right side and still had the same problem. When I use the right directional I can hear the flasher working but the bulb will not work.
Anybody have any ideas.
Thanks
darrell McCoy's Avatar
04-07-03, 03:56 PM   #2
darrell McCoy
Look for a bad ground/or connection. Could be a badsocket base contact also.
Joe_F's Avatar
04-08-03, 06:28 AM   #3
Joe_F
Bad connection or wasted flasher (yes, one side can go bad).
Do the hazards work normally?
wingplow's Avatar
04-08-03, 09:50 AM   #4
wingplow
Yes the 4 ways work fine.
Thanks for the info.
Joe_F's Avatar
04-08-03, 01:11 PM   #5
Joe_F
If the four ways work fine, you are dealing with a bad turn signal switch or turn signal flasher.
wingplow's Avatar
04-08-03, 04:25 PM   #6
wingplow
Thanks for the infomation. I will check the flasher first then move onto the switch. I will keep you posted.
Thanks.
