95 Honda Civic
95 Honda Civic
I have 95 Honda Civic Ex and I'm having trouble with it. I tried turning on my car this morning and the engin kept rolling over. It didn't want to start. This is the second time this week it has happened. The first time was on Sunday, it didn't want to start but 2 or 3 hours after I let it sit, it started. It worked fine yesterday but doesn't want to turn on today. Any suggestions on what it might be. Another thing, it currently has 115000 mile on it. Is there something I should do with a car after 110000 miles (flush the transmission, change the timing belt), somthing like that. Any help will be appreciated.
You need to determine that the basics (air, fuel and spark) are OK and all present. Without that you can't go anywhere.
Start by taking the distributor cap off. Have someone crank the engine. If the distributor rotor doesn't turn, the timing belt is broke. The engine is possibly wasted (bent valves) if this is the case.
You could also have no fuel. Again, my basics has how to check (fuel pressure gauge)
Multitude of possibilities---you have to rule them out. You can easily throw more parts at the problem than this will ever be worth .
