1988 Ranger
Old 04-10-03, 06:16 PM
KRRII
1988 Ranger
I have a 88 Ranger with 2.3 fuel inj 4cyl., 5spd manual. The problem is when it is started and is idling it seem to be getting to much fuel and runs rough. When you get on the road it smooths out and runs good but it is only getting 14 to 15 mpg. The check engine light does not come on when you go to start it. The socket and bulb in the dash check out fine. When an analyzer is hooked up it does not retrieve any data. The mechanic that is trying to find the problem has put new vaccum lines on it, new temp senor oxgen sensor,and new computer module. He told me that he could hear the injector clicking like they should. Nothing has helped. Any idea on how we can get the analyzer to receive the engine data or what we can do to get truck running better.
Old 04-10-03, 06:27 PM
i would start by checking fuel pressure may have bad fuel pressure regulator which would cause some symptoms you are describing. the computer shows no codes they may not be anything wrong with it and it may be functioning normally.
you can check auto library for fuel pressure specifications.
http://www.cybrrpartspro.com/Manual%...delLookup.html
Old 04-11-03, 03:38 AM
Joe_F
I agree with BeJay.
