1996 jeep cherokee door lock problem
Old 04-11-03, 07:47 AM
swilly
Question 1996 jeep cherokee door lock problem
my passenger door of my 1996 jeep cherokee will not close because the lock on the side of the door is stuck in the lock position i have used a screw driver to open the hook but it wont move any tricks or help????thank you
Old 04-11-03, 09:17 AM
Joe_F
Try flipping the handle when you stick the screwdriver in there. The latch may be jammed though .
Old 04-11-03, 03:58 PM
darrell McCoy
You need to remove the panel, check and see that the lock arm or latch arm is still connected. Maybe an easy fix once you get inside and see whats amiss.
Old 04-16-03, 05:20 PM
swilly
i pulled it down with a pair of plyers and a screw driver it just needs some grease and its fine. thanks for your help
