rear end howl
Old 04-11-03, 05:07 PM
billdio
rear end howl
I have a 91 Camaro 305 automatic and the rear end is howling. Is there any type of additive that would quiet this up? Thank you.
Old 04-11-03, 06:21 PM
knuckles
A howling noise indicates worn or damaged bearings or gears.
Aside from axle bearing replacement, differential service isn't really a DIY project unless you're very well equipped and know what you're doing.
No additive I've ever seen will replace missing metal. There *may* be an additive that'll quiet the noise, but it will be a short term fix at best.
The cheapest fix for this problem would probably be a used rear end assembly.
Old 04-11-03, 06:34 PM
billdio
Thank you for responding and your advice is well taken. Billdio
Old 04-12-03, 12:02 AM
WeldGod's Avatar
Did it just start howling? If it has always done it, it might be filled with the wrong oil. On some R&Pís and differentials the wrong weight or type of lube causes howling because of inadequate lubrication, or cavitation of fluid.
Old 04-12-03, 09:48 AM
Joe_F
Agree with Knuckles.
Weld: The wrong fluid causes chattering not howling (such as not adding the GM additive in a posi)
Old 04-12-03, 10:22 AM
WeldGod's Avatar
Yes, I forget that things are different with the bigger trucks I work on.
