Ring and pinion
Old 04-11-03, 07:14 PM
J A Boggan
Question Ring and pinion
Does anyone happen to know where I might find a used Ring and Pinion gear for a 95 GMC, 4 wheel drive truck? The ring gear has 41 teeth and the pinion has 12 teeth. The ring gear is approximately 8-1/2" in diameter.
Old 04-11-03, 11:56 PM
WeldGod's Avatar
Count the number of bolts on the diff cover, most likely a 10-bolt. You could find one at a junk yard. But you can get a new one for about 130$, I would just bite the bullet and snag a new one from a quality company.
Old 04-12-03, 07:14 AM
darrell McCoy
If you do not have proper tools, guages, etc. Plus knowhow, you are spinning your wheels repairing this. Requires precise setting and assembly. Better off picking up another entire unit.
Old 04-12-03, 09:43 AM
Joe_F
Both posters are correct. Buy new and have it done professionally.
