cooling system
Old 04-14-03, 04:28 PM
cooling system
97 Chevy, Monte Carlo, 3.1 v6 The gauge shows overheating, checked all the relays and the fans work with the a/c on and by direct current. I'm now looking for the temperature coolant sensor, which in my Haynes manual shows to be near the top radiator hose and has a yellow and black wire connected to it. For the life of me I can't find this. Can someone tell me where it may be and if there are different color wires than the black and yellow. Thanks
Old 04-15-03, 05:46 AM
Joe_F
Hit any GM dealer's parts counter and they will give you a print out. You'll find it in two seconds that way .
Old 04-21-03, 03:04 AM
tstokka
up where the upper radiator hose connects to the motor, follow past the hose towards the passenger side and you should see it, its burried pretty good.
