Starting Problem
Old 04-17-03, 12:49 PM
Joe
Unhappy Starting Problem
I have an '89 Ford Ranger that is a 3rd vehicle. It has been sitting mainly for the winter and when I went to start it the engine did not crank. I then jump started it and it ran all day on that day.
A couple of days later the same thing happened. My assumption was that it was the battery, so I replaced it. Again, the truck ran fine for an entire day. (Several restarts)
The next morning I tried to start it again with the same result. The engine did not crank and there was not sound at all.
Could this be a solenoid issue? Or could something be draining the battery while it sits?
Old 04-17-03, 12:53 PM
tanun
sounds like it could be a faulty alternator, and something could also be pulling current off the battery. Test the alternator to see if there is a charge coming from it.
Old 04-17-03, 01:18 PM
Joe_F
Agreed. There is likely a drain on the system. Autozone and other retailers check charging systems at no charge to the customer. Can go that route.
