Transmission Problem
Old 04-18-03, 11:37 AM
pevans
Angry Transmission Problem
I've changed the front and rear seals in the transmission of my '85 Monte Carlo. It has a V-6 engine. And the transmission is still leaking alot of fluid. It has a 16 bolt fluid pan.
Old 04-18-03, 12:27 PM
darrell McCoy
You will need to degrease the trans and pan, try and determine where it is coming from. Pan gasket or whatever. I have seen rear leaks on seal where drive shaft goes into housing, if you have an overfill on fluid.
Old 04-19-03, 03:48 AM
Joe_F
I agree.
Old 04-19-03, 02:09 PM
Is the vent tube clear of debris?Or is oil coming from the vent?
Trackbacks are On
Pingbacks are On
Refbacks are On
