Trip Computer
ronnieb3's Avatar
04-20-03, 09:13 PM   #1
ronnieb3
Trip Computer
I own a 1998 Pontiac Transport with a trip computer. Is there a way to calibrate them? It appears that the gallons read low by about 2 gallons every time I fill up the gas tank.
Joe_F's Avatar
04-21-03, 03:49 AM   #2
Joe_F
Probably working as designed. I suspect nothing is wrong. It could get costly sending that unit out to Delco to have it checked out.
mattison's Avatar
OH
04-21-03, 04:10 AM   #3
I'm no pro but I believe they do that on purpose and call it your reserve so that you don't drive until it's truly empty.
darrell McCoy's Avatar
04-21-03, 06:58 AM   #4
darrell McCoy
I think most vehicle deals like that are made to run about 30 miles after it sez fill up, so there is your 2 gal.
Joe_F's Avatar
04-21-03, 02:08 PM   #5
Joe_F
Ya, true. Most vehicles have a two gallon or so reserve built in.
On a modern fuel injected vehicle you should NEVER run that low. You risk wiping out the fuel pump by starving it for fuel. The fuel cools & lubricates the pump as well as tends to suspend dirt from getting sucked up into the strainer of the pump.
