99 siverado brakes
99 siverado brakes
Can the rotors on a 99 silverado be resurfaced(turned) my neighbor a mechanic said no, that I must buy new ones
All Data had some info about late 90's model GM's concerning rotors.
If there was no grooving on the surface, or pulsating of the brakes when applying, then rotor's need not be turned. If there were grooves, (and I THINK it was up to .060 deep) then still no turning required. But they can be turned. The "slip-on" rotors don't give near as much material to work with as the old "hub and bearing" style rotors. Got to watch the "machine to" and "discard" specs closely.
