head gasket failure
Lukin's Avatar
04-26-03, 03:20 PM   #1
Lukin
head gasket failure
92 Plymouth Sundance is not blowing any heat and there are some air bubbles moving in the rad and overflow, is this a sign of a cracked head gasket or maybe a faulty thermostat?
Thanks
darrell McCoy's Avatar
04-26-03, 04:31 PM   #2
darrell McCoy
What does temp. indicator read? You may be lucky and just have a clogged radiator. How long since flush or coolant change? Are you losing coolant? A lot of bubbles normally means you have combustion gas getting into cooling system.
Joe_F's Avatar
04-26-03, 08:22 PM   #3
Joe_F
Darrell: This model has known gauge fluctuation problems from Chrysler per bulletins on the same.
Original poster: A shop can use a gas analyzer in your coolant/radiator to determine if you have HC in your coolant. If you do, blown gasket/cracked cylinder head .
