Light problems (Turn Signal)
Old 04-26-03, 09:32 PM
R
rightoo
Noticed the other day that my Left Headlight and my Right Front Turn Signal were out. Nissan Sentra 84'
I replaced the Headlight bulb and that is working.
When I went to replace the Right Turn Signal, there was no bulb! Well, then I put a new bulb in there and it still does not work. ALL the other lights are operating fine. Are there separate fuses for each light?
Thanks
Old 04-27-03, 02:08 PM
Joe_F
Do the 4 way flashers work OK? If so, bad turn signal flasher unit.
Make sure the bulb is the right part # and in correctly. Also, check the socket and grounds for corrosion.
Old 04-27-03, 06:53 PM
R
rightoo
By 4 way flashers, are you referring to the hazard lights? If yes, then 3 of them flash and the Right Front does not light.
Bulb is correct.
Old 04-28-03, 05:48 AM
Joe_F
4 way flashers=hazard lights.
You have a wasted socket or a bad ground. Make sure the bulb is in correctly! .
Old 04-28-03, 09:22 AM
D
darrell McCoy
Do a good check with a volt-meter. Check wires. Bulb contacts. Inside socket for corrosion. If there was no bulb, possibly corrosion. Probably end up at salvage yard or buying a new light assembly.
Old 04-28-03, 08:43 PM
R
rightoo
Thanks for the responses.
I have resolved the problem.
Actually there was a missing wire. Go figure. I am the original owner and have never changed this bulb myself. Probaby some mechanic way back. No bulb and no wire.
Rather than find a new assembly I was able to just replace the missing wire. All is working fine now.
Thanks again.
Old 04-29-03, 05:50 AM
Joe_F
Good job!
