windows
uffordpat's Avatar
04-27-03, 10:36 AM   #1
uffordpat
windows
i havea79 camaro berlinetta. ihave power windows. i want to change the wheels that hold the window and guide them up and down. i have the wheels. what is the best way to change the wheels, and how do i do this? thanks.
Joe_F's Avatar
04-27-03, 01:59 PM   #2
Joe_F
Pick up a GM service manual for your F body. Money well spent.
darrell McCoy's Avatar
04-27-03, 02:18 PM   #3
darrell McCoy
A real time consuming can of worms, somewhat complicated since you have elec windows. Requires removal of panel and hardware, and probably the regulator assembly(Assume you mean the 2 small plastic/nylon wheels directly under window in the channel)
I believe the wheel "Axles" are pinned/riveted on the assembly, you need to be able to work on them on a bench. Can get pretty hairy if you have never done this before. I too would suggest getting a step by step procedure from a manual.
Joe_F's Avatar
04-28-03, 05:45 AM   #4
Joe_F
I agree with Darrell. It might be best to just get another window from a junker or order a new one.
uffordpat's Avatar
04-28-03, 06:53 AM   #5
uffordpat
windows
thank you all for your answers.
