93 Cavalier won't start
Buzzjockey's Avatar
04-28-03, 09:13 AM   #1
Buzzjockey
I've got a '93 chevy Cavalier with a 3.1L v6. The starter is not engaging at all. This was very sudden, It started fine three or four times during the day and then nothing. Is there a fusable link or a fuse to the solenoid? I tried jumping the car just in case but this had no effect.
Please help
Joe_F's Avatar
04-28-03, 09:21 AM   #2
Joe_F
Check the connections to the starter and battery. They must be clean, tight, and free of corrosion. Correct as needed.
Barring that, tap on the starter body with a hammer. If it now starts, the starter is wasted. Replace it with an AC Delco rebuilt.
Buzzjockey's Avatar
04-28-03, 10:24 AM   #3
Buzzjockey
Connections to the battery and starter look good. It is acting like the starter is not getting any voltage.
Joe_F's Avatar
04-28-03, 11:21 AM   #4
Joe_F
Do you know for sure? Do the headlights work? How about the warning lamps?
If they do, the starter is wasted in all likelihood. Have you tried to tap on the starter and see if now spins?
Buzzjockey's Avatar
04-28-03, 11:30 AM   #5
Buzzjockey
The battery was showing 13 volts and everything has plenty of power, radio, headlights etc..... I did not get a chance to check that the solenoid was getting power with my DVM as I could not reach it. The car is at a fast food joint near my home and I am getting ready to go and try to get it started again. When I turn the key I get nothing ,no click or anything. Like a bad ignition switch or something. I am going to try and engage the starter with a screwdriver and go from there.
Buzzjockey's Avatar
04-28-03, 12:18 PM   #6
Buzzjockey
I was able to start the car with a screwdriver. This means the starter and solenoid are ok but it won't crank when I turn the key.
Any Ideas?
Joe_F's Avatar
04-28-03, 12:28 PM   #7
Joe_F
Check your wiring from the switch to the starter.
JSStarkey1's Avatar
04-28-03, 12:57 PM   #8
JSStarkey1
Check the ignition switch, it may have slipped down the collumn.
Buzzjockey's Avatar
04-28-03, 12:58 PM   #9
Buzzjockey
The wiring looks ok. Is there a nuetral saftey switch or a hidden fusable link somewhere? Or could this be a problem with the ignition switch?
Joe_F's Avatar
04-28-03, 01:26 PM   #10
Joe_F
The neutral safety switch I believe is on the tranny. If it starts in neutral, the switch is bad, replace it.
Check a wiring diagram (use autolibrary.org or get a 25 dollar annual Alldata.com subscription) to see the fusible link location.
darrell McCoy's Avatar
04-28-03, 03:33 PM   #11
darrell McCoy
Still might be solenoid. I would go for that or the safety swx. You got to check connections, cant tell by looking.
Buzzjockey's Avatar
04-28-03, 06:37 PM   #12
Buzzjockey
I've checked all the connections I can find and all are good. Whatever is wrong gave no warning at all.
JSStarkey1's Avatar
04-28-03, 06:45 PM   #13
JSStarkey1
Check the ignition switch. It may be bad or out of adjustment. GMs are bad about coming loose & slipping down the collumn
