wiring schm/ a.c. after market
Old 04-29-03, 02:52 PM
pistol2fix
for the past 3 summers, I have burnt the switch out in my a.c. The wire that goes to the high, gets so hot it melts the back of the switch. Ive added a in-line fuse, to no availe.
this is an after market unit that cools perfectly. when i read the ford manual for my van, i see a 'resistor' in the a.c. wiring? i need help on what is the proper wiring, as it will soon be in the 110 degree zone. Heeelllpppp!!
Old 04-29-03, 05:15 PM
Joe_F
It would help to know the vehicle year, make, model and what aftermarket A/C system it has.
Some Fords have had problems with poor A/C switch pigtails. Any parts store should have a replacement which is upgraded with better and thicker wires.
Old 04-29-03, 05:31 PM
You could wire in a relay just for hi to take the load off the switch.Just use heavier wire on the load side of your new circuit.
Old 05-01-03, 04:30 PM
I agree with the installation of a relay..almost all Factory A/C fans use a relay for High blower setting. Without the relay you draw too much current through the switch and its not made to handle it.
Old 05-01-03, 06:44 PM
Joe_F
Original poster: Who makes your system?
Trackbacks are On
Pingbacks are On
Refbacks are On
