Front Brakes
Old 04-30-03, 06:25 PM
MMizelle
Front Brakes
When changing the front brakes on my 2001 ford windstar lx I some how push only one of the two cylinders in the caliper. I know can't get the other one in. What can I do?
Old 04-30-03, 06:39 PM
msargent's Avatar
Using an appropriate hose clamping tool, clamp the rubber part of the brake line, open the bleeder screw, then carefully push the piston(s) in. I use the old brake pad up against the pistons, so that I can push them in evenly, and equally. They make special tools to push the caliper piston in, but if your careful, a c-clamp, will work.
Don't forget to check your brake fluid level after you've replaced the pads and pumped the brake pedal up!
Old 05-01-03, 07:03 PM
Joe_F
I agree, but Autozone will rent you the correct tool at no charge .
