1997 Z71 Power Steering Pump Removal
Old 05-05-03, 09:54 AM
Texas Longhorn
I've got a '97 Chevy K1500 with a bad power steering pump. I've removed both lines, the pulley, and the mounting bolts that both Chilton's & Haynes agree need to be removed. I still can't get the thing out. Are the two manuals leaving something out, or is there a trick to removing the pump?
Many thanks.
Old 05-05-03, 10:28 AM
Joe_F
Have you had a look at the online Chilton book (autolibrary) below to see if they have something?
Old 05-05-03, 10:31 AM
Texas Longhorn
I have. They have the same instructions as my printed Chilton's, verbatim. Under the hhod, it looks like I need to remove a lot more than the book indicates, but I'm hoping that's not the case.
Old 05-05-03, 10:34 PM
knuckles
The link below is leads to the Genuine GM service procedure for your project. See if it's any better than the info you've been using.
www.batauto.com/techs/GM_service_procedure.zip
Old 05-06-03, 06:44 AM
Joe_F
Knuckles, how/where do you get that information?
I suspect it is a Mitchell subscription? I have a cool GM Service Manual link here at work, pretty cool stuff .
Old 05-06-03, 09:48 PM
knuckles
I get GM info direct from GM.
xxx
I have a legit username & password for use at work. I've seen other (functional) usernames & passwords posted all over the internet.
Old 05-07-03, 06:00 AM
Joe_F
Is it legal? How can you get that information?
You can e-mail me if you want to on this. I'm just curious.
Old 05-07-03, 09:54 PM
knuckles
It's legal for me as I have a legit username & password that my employer pays for. I suppose GM would frown on someone using a username & password they 'found' online.
We also get the same info, in the same format, on CD-ROM. E-mail me if you want more info.
Old 05-08-03, 03:56 AM
Joe_F
Will do, thanks.
Old 05-10-03, 08:00 PM
msargent's Avatar
Is the pump loose at all, since removing the pully and mounting bolts or does the pump still feel like it's bolted tight? There is a bracket on the back side of the pump, that is also bolted to the exhaust manifold stud..
Old 05-12-03, 12:58 PM
Texas Longhorn
Knuckles,
Thanks for the help. That info helped me to poke my head in a couple of other places. It turned out to be the mounting stud on the exhaust manifold that I was missing (as another poster suggested). Anyhow, I appreciate everyone's help.
