1998 GMC Sierra 1/2 ton 4.3L
Old 05-07-03, 06:47 PM
reyes45's Avatar
Question 1998 GMC Sierra 1/2 ton 4.3L
My truck started running rough whith check engine light on.
I scanned it with my OBDII scanner and got code P300(multiple
cylinder misfire) so I changed spark plugs, dist. cap, rotor, and
wires and it did not fix the problem. #3 plug dark with gas odor.
What else could it be? Thank you.
Old 05-08-03, 04:58 AM
Joe_F
Could have a bad coil, or commonly on the 4.3 the fuel injector poppets get clogged and it will run rough. Could also have a bad fuel pressure regulator diaphragm.
How's the fuel pressure?
Old 05-08-03, 04:27 PM
reyes45's Avatar
1998 GMC Sierra 1/2 ton 4.3L cylinder misfire
Fuel pressure is good. problem comes from misfire. I suspected
sparkjump in dist cap but that wasn`t the case. hink I`ll have
the ign. module and coil checked. What do you think?
Thank you for your reply!
Old 05-08-03, 04:43 PM
darrell McCoy
Joe's gotcha covered on the partial clogged fuel injector. If so GM has a decent additive. Not recommended for continous use however. Part number escapes me right now but is about 18 bucks for a bottle.
Old 05-08-03, 05:01 PM
Joe_F
Original poster: How do you know the fuel pressure's good? How was it checked?
