A/c
Old 05-08-03, 02:22 PM
ouhogfan
A/c
On a 1988 Olds Toronado where is the low pressure cut off switch for the compressor located?
Old 05-08-03, 02:49 PM
darrell McCoy
what is the problem? I only ask because any A/C work/repairs should be done by a qualified tech to prevent unwanted/un-needed injury.
Old 05-08-03, 04:41 PM
ouhogfan
the compressor will not engage even after it has been charged. I can get it to kick in if I unplug it & run leads directly to the battery.
Old 05-08-03, 04:53 PM
Joe_F
It's usually inline on one of the A/C tubes. Hit any GM dealer for an exploded view from the parts book.
I agree with Darrell.
Old 05-08-03, 06:16 PM
Jason R's Avatar
Lightbulb
www.aircondition.com
Go to the discussion forum. You can find all the information you need to work on your a/c system safely on the net if you look for it. a/c.com is a good start.
You can even get certified as a "tech", for about $20, on-line, quite easily.
Your specific question, asked at the a/c.com forum, will probably yield you a specific answer.
Old 05-09-03, 05:35 AM
mattison's Avatar
You should find it on a cylinder looking object "accumillator" usually near the firewall .
Joe has the best info though. The dealer will get you right where you want to be.
