Removing ignition cylinder
Old 05-12-03, 02:22 PM
IHATEJEEPS
Angry Removing ignition cylinder
I am trying in vain to remove the ignition cylinder from the steering column ... I have a 88' Jeep Cherokee 4.0 automatic transmission. Can you help please???
Old 05-12-03, 04:32 PM
Joe_F
See autolibrary.org below in my signature file.
Old 05-12-03, 08:46 PM
msargent's Avatar
This should be set up like a GM sterring column.. You'll need to remove the horn pad, steering wheel, locking plate, and turn signal switch(3 screws hold the plastic switch in place, gently lift it aside, don't completely remove from steering column.) There should be a lock screw that can be removed to then remove the tumbler assy. from the column...
Old 05-13-03, 07:38 AM
Joe_F
True. Autolibrary.org should have it.
