water leaking inside around windshield
My 1990 bonnyville is leaking water. It's wet across the windshield and also along the driver and passenger doors only on the roof. I'm thinking I need to seal up my windshield. It does have a few cracks in it but it has high mileage so I don't want to invest in a new one. Is there something special I need to use or can I just use some silicone that I would use in my bathroom? Anything I should know about application? do's and don'ts. thanks alot
Do: Replace the windshield because it could cost your your life in an accident. The windshield is a very important part of the vehicle crash structure.
Do Not: Attempt home repair on a windshield. Not a DIY repair.
If you're at wits end with the vehicle, pitch it now and count your losses or install a used windshield. Believe it or not, Safelite and other glass chains will install a new window for probably around 250 bucks on something like this. Well worth it.
put a new windshield in my Pontiac and drove it off without
looking it over. When I got on the highway it was like driving
in a wind tunnel! Seems they forget to seal the bottom edge of
the windshield all the way across! Once I got back to the shop,
they were real good about fixing it right! I concur with Joe,
only a qualified shop should replace auto glass. It's too
important not to do it right.
