91 Toyota PU
Old 05-13-03, 12:47 PM
jcpike
91 Toyota PU
How do I check to see which one of the universal joints is bad, or should I replace all of them?
How can I check the carrier bearing?
I'm getting a vibration and squeaking when taking off
Cheers
JP
Old 05-13-03, 02:15 PM
Joe_F
Sounds like wasted U-joints. I'd change them: Old truck, many miles, lots of stress.
Should be good to go then. If you grab the driveshaft in park and feel lots of movement, they are wasted (based on the noise, they likely are).
Old 05-13-03, 02:25 PM
Take the shaft to a driveshaft shop or let the auto parts replace them. Auto parts charge around $15 a joint labor, they are small joints and a bear even for an experienced person
The driveshaft shop will charge more but they will balance the shaft
Larry
Old 05-14-03, 06:07 AM
redneck
The shaft is factory balanced--unless you altered it, or one of the tacked on weights was knocked off--you should not need to balance it! U-joints and a carrier bearing are good insurance on a high miler!
