chevy engine year
mrblue's Avatar
TX
05-15-03, 04:04 AM   #1
chevy engine year
I have a 76 firebird and believe it has a chevy 400 in it..Is there a number i can pull off the engine that will let me know for sure the year of
the motor that was put in it. I will be looking for a manual and parts on it. it has a point ignition system on it and having trouble getting fire..
Joe_F's Avatar
05-15-03, 06:18 AM   #2
Joe_F
Look at the oil filter. If it's on the left side of the engine, it's a Chevy engine. Pontiac engines have it on the right side on an angle.
On Chevy V8's, the numbers are on the alternator pad (behind the alternator on the block). Give me what you find (a three digit suffix code like CBA, a date code and a partial vin # stamp).
If it's a Pontiac V8, the numbers are behind the timing cover on the engine. It starts with 2 for Pontiac division.
In short, post all numbers you find and the details of it and I'll tell you what it is.
mrblue's Avatar
TX
05-15-03, 04:50 PM   #3
Thanks Joe
Well i found the filter to be on the left hand side ( passenger). The numbers i come up with are on the front of the block on the left hand side.
co33896 (pretty sure the 8 is not a 3)
yx (under it)
the heads have 6x in the middle and GM2 on the end.
If i need more info please just let me know.
Also is one of the engines better than the other
as far as 400's go..??? (if it is a 400)
thanks
Don
knuckles's Avatar
05-15-03, 10:15 PM   #4
knuckles
The passenger side is the RIGHT side of the engine. You have a Pontiac Engine.
mrblue's Avatar
TX
05-16-03, 03:36 AM   #5
guess i was looking from the front of the car
Joe_F's Avatar
05-16-03, 05:47 AM   #6
Joe_F
Possible 400 from a 1971 to 1972 B Series (Bonneville, Catalina, etc).
You're missing the vin # stamp. It starts with 2 for Pontiac.
6X heads are definitely Pontiac. I have them on my 1979 Trans Am 400 4 speed (they are original).
You can go to any site that has Pontiac #s and it will help. Type "Pontiac V8 engine numbers" in www.google.com
mrblue's Avatar
TX
05-16-03, 01:58 PM   #7
thanks for the info.. I will do that search on the numbers when i get them.. But i am still curious about the difference in the two.,
chevy,pontiac (gm). Is one a better performer than the other.
Joe_F's Avatar
05-16-03, 04:06 PM   #8
Joe_F
Depends who you ask. A Pontiac can be made to run with the best of them---but Chevy is as common as dog poo and can be made to run a lot cheaper.
My vote? It's a Pontiac. Should have a Pontiac engine.
SpiderGear's Avatar
05-16-03, 06:59 PM   #9
SpiderGear
Give this site a look at ;
http://www.boyleworks.com/ta400/psp/blockID.html
Maybe, re-check the #####'s.
It don't look like you have enough ######'s.
