noise ignition
Old 05-17-03, 05:17 PM
weld
noise ignition
93 XLT 4.0.There is a click when I turn the key to start and a click when I let the key off start.Sounds like a solenoid.Is not the starter or starter relay.Inside the sound comes the right side kick panel where the PCM is.Under the hood sound comes from ICM behind the battery at the radiator.Is the PCM or ICM going bad?Explorer starts right up no other noise.
Thanks Weld
Old 05-18-03, 06:41 AM
Joe_F
Not sure there is an actual problem....
Old 05-18-03, 08:55 AM
weld
thanks for reply
weld
