Older explorer slips into neutral.
pjb1's Avatar
05-20-03, 05:27 AM   #1
pjb1
When first staring my 93 Explorer in the morning and backing it out of the driveway, it has a tendency to slip back into neutral. If I play with the gear selector - park, D, back to R, etc it grabs again. Once I take off in drive, it go3s through the gears smoothly, and the problem won't repeat until the next morning when it is cold again.
Joe_F's Avatar
05-20-03, 05:46 AM   #2
Joe_F
Sounds like a wasted tranny. Last time the fluid and filter were serviced?
pjb1's Avatar
05-20-03, 06:09 AM   #3
pjb1
Shes got 107,000. Did fluid and filter at 45 and 90. Why do you think it only does it when cold?
Joe_F's Avatar
05-20-03, 07:23 AM   #4
Joe_F
Wasted pump perhaps (internal failiure). That is WAY too long on a fluid change. Every 25k for the fluid and filter.
Have a good tranny shop diagnose it and if it's deemed to be bad, drive it until a rebuild is needed.
