89 lincoln air ride
Old 05-20-03, 03:07 PM
moody
89 lincoln air ride
I believe i have a leak in my rear air ride system on a 89 continential (auto, 3.8l) & have been told that tire stop leak could fix this problem. is this possible? the car will level out for about 5 minutes, then leak down, i can pull over, turn the ignition off, start it up again & it will run another 5-10 minutes before the tires are rubbing. any suggestions?
Old 05-20-03, 04:48 PM
darrell McCoy
If you intend to get it repaired, dont hob nob with stop leak. Waste of time. The age and miles I would suspect you have a shock leaking. I'd have it checked and then weight the repair cost to a conversion kit. This stuff can get into your dinner bucket pronto. Hopefully tho it is something very simple.
Old 05-21-03, 05:10 AM
Joe_F
I agree. This is a piss poor system not worth 50 cents.
There is likely a leak in the air strut or lines. $$$$$$$$$, but there are aftermarket companies with some of the parts now.
Old 05-22-03, 08:40 AM
Joe_F
Another option:
Monroe for one company, makes a conversion kit to get rid of the electronic suspension and make it convential, which is much cheaper.
Check it out at www.monroe.com
Old 05-22-03, 08:47 AM
msargent's Avatar
22+ years and that's a first for me.. Stop Leak in an air ride...
Personally, I don't recommend stop leak in tires, let alone something it wasn't designed to be put in...
My cent...
