A/C 93 Suburban
Old 05-21-03, 12:18 PM
BuzzKutts-Revenge
Question A/C 93 Suburban
The A/C works ok as long as the engine is under a load. When I sit at idle it doesn't blow cold. Any advice ?
Old 05-21-03, 01:29 PM
Joe_F
Low pressure, perhaps a cooling system issue. Time for professional service.
Old 05-21-03, 06:30 PM
BuzzKutts-Revenge
Question
Low Pressure ? Can you elaborate a little.
Old 05-22-03, 12:16 AM
cheese's Avatar
Received 20 Votes on 17 Posts
Could be low on freon (low pressure). It could also be something simple like the fan clutch slipping, or if electric fans, the accessory fan may not be coming on. If this is the case, your head pressure may be developing to such high pressure that compressor damage can result. It could be other things as well, but these would probably be the most common.
Old 05-22-03, 10:09 AM
BuzzKutts-Revenge
Thanks I will take it to the A/C guy tomorrow.
Again thanks for the advice.
